infra:depot_linux [2020/04/28 12:04] rapacchd |
infra:depot_linux [2022/07/18 11:11] rapacchd |
Ligne 12: | Ligne 12: | ||
Ligne 23: | Ligne 23: | ||
apt-cache search im2ag | apt-cache search im2ag | ||
+ | im2ag-glfw - GLFW\\ | ||
+ | im2ag-pyzo - Pyzo\\ | ||
